- Loopysue
- 9,991
- Member, ProFantasy
- 9,866
- June 29, 1966
- Dorset, England, UK
- Real Name
- Sue Daniel (aka 'Mouse')
- 27
Community Atlas Where ?
Yes. That's what I was saying. I've noticed several times before now that if something is quite small, or in this case thin, shadow effects don't always work as expected.
I tried little tiny people for the new city style, but I gave up because it was impossible to get them to cast nice shadows where they were so tiny.
WIP - Water's Edge Exercise Distraction
Convert Map Style to Look Drawn
Here is how I would do it if I just wanted a background with nothing fancy, like scrolls or ragged edges.
- Add a new sheet on top of your map (bottom of the list)
- Add a Blend Mode sheet effect to the new sheet
- Set the Blend Mode to Multiply
- Draw a rectangle of the desired parchment fill over the entire map on that new sheet.
- Refresh the drawing
You may find that this trick works better with black and white styles, but it does depend on the style. Here is an example:
You will find parchment fills in the Bitmaps\Tiles folder and subfolders depending on what add ons you have. If you can't find any you like in there, there are some free here:
https://www.profantasy.com/products/subsamples.asp#&panel1-1
New member greeting
Precise angles
Yes there is. You can specify the angle of a line by using keyboard inputs to position subsequent nodes following the first one.
But if all you want is 45 degrees then use the snap grid. It's a lot faster than all that typing. A line that crosses the same number of horizontal grid squares as vertical ones is always 45 degrees.
