- Loopysue
- 9,992
- Member, ProFantasy
- 9,867
- June 29, 1966
- Dorset, England, UK
- Real Name
- Sue Daniel (aka 'Mouse')
- 27
How does the Displace effect work?
Rotaliana WIP. A dark map of home.
Map border not lined up with Snap after scale
I had this problem myself not that long ago, and it was caused by the lack of a map note.
If you open the map notes |CC2NOTES| there should be one there called "Resize".
If its not there create a new map note and call it Resize
Ok will bring up an Edit Text box, into which you need to type the command "Stretch".
Ok makes everything vanish, but if you open the map notes again you will see the Resize map note has been added.
Now try resizing your map again.
Pen & wash question
Trying out a Planescape style
