9,992
Member, ProFantasy
9,867
Birthday
June 29, 1966
Dorset, England, UK
Real Name
Sue Daniel (aka 'Mouse')
27
  • How does the Displace effect work?
    The effect can also use an ordinary png image to generate the displacement.
    Not being a technical person I can't explain the exact maths, but the visual appearance of the image or normal map should give you an idea of what the displacement will look like.
    roflo1AleD
  • Rotaliana WIP. A dark map of home.
    I love it :)
    Might need a few place names, but nothing too 'shouty' or it will overpower the map.
    AleD
  • Map border not lined up with Snap after scale
    I had this problem myself not that long ago, and it was caused by the lack of a map note.
    If you open the map notes |CC2NOTES| there should be one there called "Resize".
    If its not there create a new map note and call it Resize
    Ok will bring up an Edit Text box, into which you need to type the command "Stretch".
    Ok makes everything vanish, but if you open the map notes again you will see the Resize map note has been added.
    Now try resizing your map again.
    Glitch
  • Pen & wash question
    I agree! I can't see much difference, but I also prefer A. It's thinner, isn't it?
    roflo1LillhansAleD
  • Trying out a Planescape style
    Looks like you're really getting on well.
    Another way to do it is to keep the plain white fill and put the parchment over the top of everything else and use a Blend Mode sheet effect set to Multipy 100% on that sheet. It's how I add parchment texture to other black and white styles.
    roflo1Glitch
