9,992
Member, ProFantasy
9,867
Birthday
June 29, 1966
Dorset, England, UK
Real Name
Sue Daniel (aka 'Mouse')
27
  • Marine Dungeon - further developments
    I've hit a problem with a new and very last minute idea of connecting stones to make odd-shaped wall bits that can't be done with the main connecting wall set. Unfortunately, it keeps missing stones, but I don't know everything about connecting symbols, so I'm hoping someone else has tried this before and knows what I'm doing wrong here.
    There are no corner parts and nothing has a defined length. the exact length of the stones varies because they were extracted from the main wall symbols.
    I did say it was a last minute idea.
    EDIT: I forgot to name them properly! 🙄
    MonsenTheschabiCalibreJimPWyvernAleD
  • Displace moving everything to the left
    Thank you, Raiko
    I did some better waves yesterday, and then had to change the ripples quite a lot to make things sit right with the rest of the style.
    Hope you still like it.
    TheschabiMonsenroflo1RaikoGeorge[Deleted User]seycyrusCalibreJimPWyvern
  • Community Atlas - The Bleakness - Ashburton - Darklands region and Darklands City
    They look good, Quenten :)
    That blur on the border ribbon was meant to be just a tiny shadow to make the ribbon look raised, and might need a bit of adjustment.
    It was your thread that gave me the initial idea to do this :)
    It works ok if you use the correctional displacements after the main one. One red and one green. They are just 500 px bitmaps of pure red and pure green.
    There's no rhyme or reason to the actual amount each will be required, but at a scale of 500 I needed a displacement value of anywhere between 0.2 and 3.0, depending on how bad the drift was. Using the same values in both green and red correction displacements to start with helped a lot, otherwise it is a bit like trying to saw just the right amount off the legs of a rocky table without a tape measure.
    JimPWeathermanSwedenroflo1Raiko
  • Suggestions on how to make river connecting to ocean smoother/more natural?
    It sounds like you had a line width other than zero. Any polygon with a line width greater than zero will have a hollow centre. Use Change Properties to correct it.
    roflo1
