- Loopysue
- 10,007
- Member, ProFantasy
- 9,874
- June 29, 1966
- Dorset, England, UK
- Real Name
- Sue Daniel (aka 'Mouse')
- 27
WIP: The Rocks, Sydney 1930's Street Annual
How to draw an arrow???
cutting up a continent
Are you saying it was too slow on the larger map? That can make things seem uncertain. Other than that things should behave the same way if you do them the same way between maps.
If things are slow now before you ever add anything but the land, then it could be that you have too many nodes for comfort. The problem only multiplies as you add terrain and trace along the existing coastline for the edge. If this is ringing true to what you are seeing, I recommend using the SIMPLIFY keyboard command to reduce the total number of nodes. You would be surprised just how many of the nodes in a coastline don't actually do anything because they are too close together to be noticeable.
Land Editing not Affecting Coastline in M.S. Ink
There's a loop in the line at that point. If you look at it as if it was a road you were driving down starting from the left, when you get to that point you are heading to the northernmost point first, and then the southern point second. Jim is right - you just need to decide which of those points is the one you want and delete the other one using the delete node tool |CC2DELNODE|.
If you are having trouble hitting the point it's not at the very tip of the line because the line has a width. The nodes are in the centre of the line width, so it will be a short distance in from the tip of the point.
