- Loopysue
- 10,008
- Member, ProFantasy
- 9,874
- June 29, 1966
- Dorset, England, UK
- Real Name
- Sue Daniel (aka 'Mouse')
- 27
Need a tutor
Hi stubbjo8 :)
Its not something that we've had a request for before, so there are no official tutors.
Have you tried any of the Live Mapping sessions or video tutorials? We do all levels. https://forum.profantasy.com/discussion/10519/video-tutorials/p1
The best bit is that if you get stuck with anything in particular you can always ask right here - and its free :)
Darkland cities tools showing as blank
In the first instance, that's not right. There is an FCW file containing a sample of each of those fills in the Drawtools folder that should be showing itself in each of those field tool images. But I can see from my own installed copy of the template that this isn't happening.
In the second instance - colour 6 is the knockout colour that punches a hole in the water to reveal the land and make an island, so that is perfectly correct.
I have reported the invisible fields as a bug.
Wet medley and a city!
There any master printable lists of symbols?
Hi :)
If you open the catalogue file (that's the [Foldername].FSC file usually visible in the parent folder of the [Foldername] containing the symbols), you can export an FCW file with all the symbols arranged neatly and ready for printing using the "Create catalog thumbnail file..." option.
In this example I created a Test.FCW file on my desktop which looked like this when opened.
The blank space at the top left is a drawtool and not a symbol, so it's name is there but the sample line is not.
I then exported a jpg bitmap from this and got this result (this is only a 500 px export to preserve the copyright on these symbols on the forum, but you can set it any size you prefer using the Options button in the Save as dialog.
This works for each catalogue at a time, but it doesn't take too long to do, and if you print each one you can make a reference book of them for yourself.
