9,968
Member, ProFantasy
9,853
Birthday
June 29, 1966
Dorset, England, UK
Real Name
Sue Daniel (aka 'Mouse')
27
  • Issue with beach on Spectrum Overland
    It's possible the beach isn't wide enough to go completely under the faded edge of the grass. Try editing the EFI on the grass sheet to make the faded edge narrower. The alternative is to use the node edit tool|CC2DYNEDIT| to move the nodes of the inner side of the beach polygon further under the grass.
    The nodes aren't visible in CC, so it's a case of clicking with the node edit tool on the inner edge of the beach poly until you grab one. You then move it by dragging the mouse and then click to reposition it. On to the next node... and so on.
    Don Anderson Jr.
  • Flooring Maps
    Sure you can :)
    Start a new map of that style, but make it big enough to contain all the floors you have - so maybe twice the width and three times the hieght, or three times the width and twice the height (for all 6 levels to be together in that one large map).
    Then copy and paste just the structure and labels (without the legend or hyperlinks, or any of the background and frame bits and pieces) from each of your existing maps into the new map. That way you still have all of your original single level maps as well as the new grand house plan of everything.
    KertDawgDaniUG
  • Map Size - ReSize
    Ah yes, good point Don.
    That's another keyboard command. Type and hit enter. You will need to read the prompts in the command line at the bottom though. It will ask you for a distance. Use 0 (zero) to start with. If that doesn't do the trick try 0.1.
    Don Anderson Jr.
  • Atlas Submission: Doriant - Gold Coast - Tyr Alomere
    A superb effort, Royal. And lots of beautiful maps.
    RickoRoyal Scribe
  • [WIP] Villa Citri (Roman-style villa)
    I prefer the outer glow option. Good choice.
    Royal Scribe
