- Loopysue
- 10,009
- Member, ProFantasy
- 9,874
- June 29, 1966
- Dorset, England, UK
- Real Name
- Sue Daniel (aka 'Mouse')
- 27
Live Mapping: Fantasy Realms (Annual Vol 3)
CC3+ Going back to the basics-Dungeon
It looks pretty good, though there do seem to be a few artefacts of something not quite right around that join between the cave and the rooms beyond it.
Check that you haven't doubled up on the walls anywhere. That is the most common cause for windows and doors not cutting the wall as expected. If there are two walls the door/window will only cut one of them and then be hidden by the other.
Use List from the Info menu on a piece of suspect wall to find out how many walls are really there.
CC3+/DD3 - Program Freezes When Trying to Copy DD3 Light Source
I don't know if those keys are supposed to work or not, because I've always used the clone tool (my bad - it's actually called the Copy tool, but I use a lot of different software, and keys that do this job are often called clone tools).
I believe the copy and paste keys should also work, so I will investigate...
The Creepy Crypt project
