10,009
Member, ProFantasy
9,874
Birthday
June 29, 1966
Dorset, England, UK
Real Name
Sue Daniel (aka 'Mouse')
27
  • Live Mapping: Fantasy Realms (Annual Vol 3)
    Hi everyone! :D
    This week, Ralf will be using the Fantasy Realm style of the Cartographer's Annual Vol 3 to draw an overland map in a classic D&D style.
    We hope to see you there, but if you can't make it you can always see the show later :)
    JimPRicko
  • CC3+ Going back to the basics-Dungeon
    It looks pretty good, though there do seem to be a few artefacts of something not quite right around that join between the cave and the rooms beyond it.
    Check that you haven't doubled up on the walls anywhere. That is the most common cause for windows and doors not cutting the wall as expected. If there are two walls the door/window will only cut one of them and then be hidden by the other.
    Use List from the Info menu on a piece of suspect wall to find out how many walls are really there.
    Octorilla
  • CC3+/DD3 - Program Freezes When Trying to Copy DD3 Light Source
    I don't know if those keys are supposed to work or not, because I've always used the clone tool (my bad - it's actually called the Copy tool, but I use a lot of different software, and keys that do this job are often called clone tools).
    I believe the copy and paste keys should also work, so I will investigate...
    Thomas Davis
  • The Creepy Crypt project
    Thank you, both :)
    There have been too many requests for more flexible stair options in the past for me to ignore. Plus, I was doing the regular stairs anyway and had a few spare.
    I might be getting slightly off topic here, but I made some rocks that can double as cliff material.
    But we do need the stuff to generate the right sort of mood, so maybe not?
    DaltonSpence[Deleted User]JimProflo1AleDWeathermanSwedenLauti
