10,014
Member, ProFantasy
9,874
Birthday
June 29, 1966
Dorset, England, UK
Real Name
Sue Daniel (aka 'Mouse')
27
  • The Creepy Crypt project
    Never seen either of those things before, but I'll see if I can fit them on the list for you Joe :)
    The wasp nests remind me of... Alien!
    I imported them at 200 px per map unit, so you can make them larger if you want, but I think they might be a bit obvious at full size if you are trying to hide them among the fragments. Full size would be if you want them to be noticed straight away.
    JimPGlitch
    Do you mean something a bit like this, @jslayton? Something where you don't actually know for sure what it was that just hatched out?
    MonsenJimPWyvern
  • change size of map
    Just hide the SCREEN, BACKGROUND, MAP BORDER (sometimes called a similar name), and FRAME sheets, and grab the whole lot in one selection box.
    If there is a lot of stuff being moved it is quite normal for the screen to slowly flash as it continually refreshes the moving parts no matter how many moving parts there are. It won't crash, though, unless you get impatient and start clicking things to try and hurry it. The larger the map to be moved the more stately the speed you can do it at.
    goffchileGlitch
    You can use the Resize Drawing Area option in the File menu to adjust the size.
    When the dialog opens it will show you the current size of the map in map units. Edit those numbers to change the size of the map. The existing drawing will remain as it was in the bottom left corner of the new drawing area, but it's easy enough to move it if you wanted more space all around.
    goffchile
