- Loopysue
- 10,016
- Member, ProFantasy
- 9,874
- June 29, 1966
- Dorset, England, UK
- Real Name
- Sue Daniel (aka 'Mouse')
- 27
Despite my best efforts, I CANNOT go back to main view from expanded view of symbol categories
[WIP] a watersource in the woods
Hi Fersus :)
There are shadow sheet effects that should achieve what you describe. Try hiding that drawn shadow sheet and instead adding a Wall Shadow, Directional sheet effect to the sheet with the trees and then editing it to check the drop shadow option in that effect.
I've done several water effects, both in sheet effects and symbols in different styles. The greatest number of them are in Marine Dungeon, but there are some in Darklands City. I can't be sure which you mean.
Al Shammar - Cities of Schley fortified oasis
Why doesn't my jpg look like the image in CC3+
Here are the settings I use to generate a reasonably clear map, though the larger the area of the map the larger I go with the number of pixels width and height - up to 6000. Don't worry about the proportions being square. This setup should automatically crop to whatever the proportions of your map are. That's what those two options I have checked at the bottom do.
The Creepy Crypt project
