- Loopysue
- 10,019
- Member, ProFantasy
- 9,874
- June 29, 1966
- Dorset, England, UK
- Real Name
- Sue Daniel (aka 'Mouse')
- 27
Can't TAB through some Symbols - Creepy Crypt
[WIP] August Mapping Competition -- The Blue Rose Tavern
It's looking really great :)
You could still use FLOORPLANADD. If the map itself is a different size you can use Resize Drawing Area in the Draw menu to correct that so that it matches the other levels. If the layout is the wrong size you could delete it and copy and paste from another floor using the map origin as the copy and paste origin. Then, even if you only want the walls from the other level's map, or the walls and the stairs and dividing walls, you have a head start on things.
Forest Trail project - part 1
@jslayton - one fairy ring kit (separate toadstool groups) :)
