- Loopysue
- 10,020
- Member, ProFantasy
- 9,874
- June 29, 1966
- Dorset, England, UK
- Real Name
- Sue Daniel (aka 'Mouse')
- 27
Map with x signs
If that is where the FCW file started out, then you will be fine as long as you never move the map from your desktop. To use your symbols more freely and be able to move your maps around without worrying about red Xs you really need to store all your symbols in subfolders of the Symbols folder.
These videos by Remy Monsen explain a lot of things about importing third party symbols if you are interested.
https://www.youtube.com/playlist?list=PLulP-cGMLxw4qTpXfilRHgbDUg8WvrEX2
If you need to upload an FCW again you can do that right here on the forum. Just click the attachment paperclip. Or you can do the same in a private message to one of us if you prefer.
an experiment in iso/perspectives
Need Style Suggestion for Azeroth (World of Warcarft) Map
Ok, well, that's not an easy one. I would pick a style and use it as the style it is to avoid spending weeks trying to modify it well enough to become a facsimile to one of those maps. Using one of our styles out of the box may also make it clear that you aren't copying the original artworks in anything other than actual layout.
With that in mind I guess whatever styles you feel will give you the right mood. Remember that you can do a lot to change the colours of existing map styles by playing with sheet and whole map effects.
Forest Trail project - part 1
