- Loopysue
- 10,020
- Member, ProFantasy
- 9,874
- June 29, 1966
- Dorset, England, UK
- Real Name
- Sue Daniel (aka 'Mouse')
- 27
Which styles work best with each other as you scale down from world to regional?
Live Mapping: Classic Fantasy
That drawing tool draws a solid polygon of magenta on the forest sheet. Because there is a Color Key sheet effect on that sheet set to magenta, the magenta polygon cuts a hole in the forest fill, leaving the parchment beneath it exposed.
Try it out - draw your polygon around the text where you want the hole in the forest behind it, and then refresh the view.
Cartographer's Annual - all the issues linked in one place
