10,021
Member, ProFantasy
9,874
Birthday
June 29, 1966
Dorset, England, UK
Real Name
Sue Daniel (aka 'Mouse')
27
  • The Legendary Panyang
    Maps are good for distraction :)
    I hope you feel better soon.
    EukalyptusNow
  • Forest Trail project - part 2
    Oh dear, Julian. The work on part 2 focussed primarily on waterfalls and cliffs. I've lost 3 weeks work because of PC troubles (blue screen of death) and now there are only 13 days left to the handover deadline.
    I think you will find there are some pine trees, and there are already 2 different colours of water. Caves are easy to do (see below)
    My main focus in the last fortnight before handover (some of which is dotted with unavoidable appointments and other interruptions), is to sort out the rapids and flow marks for the water, but I will see if I have time to do a square tower.
    JimPEukalyptusNowroflo1adelia hernandezCalibredragarhirOctorilla
  • Forest Trail project - part 1
    To keep the two parts of this project separated I've started a new thread here:
    https://forum.profantasy.com/discussion/13068/forest-trail-project-part-2
    Ok, so there's already been a bit of work for this part of Forest Trail, but it was tacked onto the end of the part 1 thread. I've had serious PC problems which are mostly resolved now, but work has been a bit slow.
    Still working on the waterfalls, but while everything was in upheaval I decided to add a couple more compasses to the style. I couldn't decide on the design so you've ended up with interchangeable parts.
    Jeff B[Deleted User]JulianDracosJimPCalibreMonsenRickoMaidhc O CasainEukalyptusNowBwenGunand 7 others.
  • Invasion of Warlock
    The easiest way to test a symbol catalogue is to try making a new map with it. After a while it becomes more obvious that it is either already in the right order for everything to be convenient, or that a few changes might be necessary to avoid unnecessary searching.
