10,020
Member, ProFantasy
9,874
Birthday
June 29, 1966
Dorset, England, UK
Real Name
Sue Daniel (aka 'Mouse')
27
  • Dwarf Home, Old Crestar
    It looks like you've got more than half way there, so starting again by importing everything into a new MD map might be even more of a time waster, since you would only then have to copy all the sheet effects from this map into the MD map. It's probably better to carry on and copy the sheet effects you need across from an open MD map. When you have two maps open side by side like that remember that having autosave turned on can cause a crash, so best to turn it off for the duration of the operation if you normally have it turned on
  • Cartographer's Annual - all the issues linked in one place
    Updated today to March 2023
    JimProflo1Wyvernarsenico13
  • Winter Trail Project
    Oh yes. That animal track was meant to be a big cat, but there were several things wrong with it including that I made the mistake of judging the size of the prints against a 10 ft grid that I thought was a 5ft grid. Now that I've sorted it out it looks a lot better ;)
    But just because it's not a great cat track I've called it 'Beast' instead of 'Cat'.
    Getting close to finished here. Until now I've been working on a conversion of my Forest Trail part 2 example map, but now I've started a simpler example map to tweak things like drawing tools that aren't working right, and symbols that don't go to the right sheet.
    Wyvernkilma.ard.venom
  • Live Mapping: Dark Fantasy Vector Symbols
    Hi Everyone! :D
    In tomorrow's Live Mapping session, Ralf will be demonstrating how you can create your own vector symbols using the Dark Fantasy overland style as an example.
    You can watch it here on the forum:
    Or you can come and join us on YouTube here: https://www.youtube.com/watch?v=15w1kb7qGmI
    It would be lovely to see you there :)
    [Deleted User]JimP
