10,020
Member, ProFantasy
9,874
Birthday
June 29, 1966
Dorset, England, UK
Real Name
Sue Daniel (aka 'Mouse')
27
  • Auto generate maps by standardized input files
    Hi Florian :)
    We don't currently have a random land mass generator built into CC3, but if you have Fractal Terrains you can generate an infinite number of worlds and export them, or parts of them, as CC3 maps. That lays down the coastline and contours but you still have to add the fills and symbols yourself in the CC3 map.
    We have a simple random city generator that comes with CD3, and you can also import data from Watabou random city generator to CC3 and use it to generate your own city map, whether you just trace the image or get a more direct result. The process is described in the January issue of the 2020 Cartographer's Annual, which also provides a style to use so that you can realise your Watabou cities fairly quickly.
    We don't currently have a random dungeon generator, but you can import images from any other random dungeon generator to use as a guide to draw your own in CC3.
    Florian Ostermeier
  • Color key isn't working again
    No need to apologise!
    I hope you are feeling a lot better now :)
  • Any Feedback to my first CC3+ Map?
    A sky island...
    When you turn the sheet effects on you could try dding a Drop shadow sheet effect to the LAND sheet, to make it look more like it is flying.
    JulianDracosSirus0
  • stone carvings
    I can't see any ill effects with the MERGE layer frozen in the map I've got open, but do let us know if you have any.
    Fersus
  • a large city, I have been putting off, now started
    You don't have a lot of luck with cars do you!
    Hope its better news than you think.
