9,966
Member, ProFantasy
9,852
Birthday
June 29, 1966
Dorset, England, UK
Real Name
Sue Daniel (aka 'Mouse')
27
  • Live Mapping: Character Artist 3
    This week, Ralf will be taking a look at the Character Artist add-on for CC3+ to build a character and a monster, and create a paper standee for printout.
    Come along to youtube on the day to join in the live chat here:
    https://www.youtube.com/watch?v=A35xcjcvKiw
    Or watch it any time here on the forum:*
    *This thread is not monitored during the live show, but is a place where you can chat about the event and ask questions.
    Your local time for the event is displayed in the forum side bar.
    ScottAQuentenRoyal ScribeRyan Thomas
  • Best methodology for designing islands "by hand" with FT3
    Have you looked at The One Day Worldbuilder pdf included with FT? (ProgramData\Profantasy\FT35\Documentation)
    I'm not suggesting that you make a whole world, but it might help you get a few ideas about resolutions and methods.
    Remember that if you change the resolution on an existing world the shape of the landmasses may change quite a bit.
    Ryan Thomas
  • Instruction Clarification Page 59 Tome_3Plus.pdf
    When it next does that to you check the command line to see what CC3+ is doing. It may be that you haven't finished a command.
    There could be other causes, of course, but that's always the first place to look for clues.
    Goblixie
  • Using End Modifier Tool and a bit confused
    At the point in the process where you right click (after you have picked Copy from the Edit menu) you should get this pop up
    The Window option is 6th in that list. Pick it and then continue with the process. I think the bits you don't understand will become clear to you once you start with the Copy tool in the Edit menu.
    If it doesn't, just say.
    GoblixieDon Anderson Jr.
  • Which Directory is for Fills?
    Very generally they all go in the ProgramData\Profantasy\CC3Plus\Bitmaps\Tiles folder, but there is a well developed structure in that main folder, as you can see below.
    The annuals each go in one of these subfolders (above) according to what basic type they are - overland in the Overland folder, dungeon styles in the Dungeon folder, etc.
    These are all the annuals in the Bitmaps\Tiles\Overland folder - all the overland annuals are there in their named subfolders.
    Perhaps it's worth noting here (although it wasn't part of your question), that we encourage all user-generated fills to be put in a folder called USER placed in the Tiles folder, rather than scattered all over the place within the subfolders. It's a lot easier to copy your stuff and keep it safe if you get a new PC or have to do a major uninstall reinstall at any point.
    ScottA
