9,992
Member, ProFantasy
9,868
Birthday
June 29, 1966
Dorset, England, UK
Real Name
Sue Daniel (aka 'Mouse')
27
  • Where are bitmaps 'CA51' please
    The location of any bitmap file is given in the Fill Style dialog box in the 'file' window.
    If you want to add them to another map it's probably easier to use Insert file in the Draw menu, and pick the old map you mentioned but press ESC just before you paste it. Doing it that way will also import the correct scale from that old map.
    JackTheMapperroflo1
  • Sinister Sewers - Style Development Thread (CA207)
    I got so busy doing things and having various household appliances break down on me (like the boiler - just before the coldest week so far) that I forgot to show you the example map I did for Sinister Sewers, which was published yesterday as the March issue of the 2024 Cartographer's Annual.
    I know there's a huge gap between the last image I posted and this one, but that's just the way life happened to me right at the end of developing this style.
    MonsenRoyal ScribeWyvernRicko
  • Sheet Effects stop working consistently
    You're welcome :)
    It's not part of the manual. Just something that keeps happening to me, but I do spend a lot of time really pushing the software hard when I'm working on new styles. When it happens to other people it's usually quite rare.
  • Creating greater depth
    You do have to have as many ROADS sheets as you do tiers, and then one more to try and blend any joins... unless you hide the join with a bridge or a tree.
    JackTheMapperRoyal ScribeJimP
    I think you are doing well with the contouring. It does take some time and patience to get it right. Roads are a tricky one. I did a city a long time ago and cheated a little bit by using 6 or 7 tiers a bit like a disorganised wedding cake. That way each tier cast a shadow where necessary over the roads and houses on the tiers below.
    JimPRoyal ScribeJackTheMapper
