9,977
Member, ProFantasy
9,859
Birthday
June 29, 1966
Dorset, England, UK
Real Name
Sue Daniel (aka 'Mouse')
27
  • Making a Mountain
    Height in a CC3 map is always an illusion. We don't currently have any heightmap features in CC3. Automatic roof shading is achieved by a specialised normal map applied to each building the moment it is placed in the map.
    CC3 normal maps are linked with the symbol file in the symbol graphics folder, and only contain information about how steep the roof is, and which direction it is facing relative to the sun as blue and red components.
    The connecting cliff symbols have normal maps that function in the same way, which is why they look darker on the face away from the global sun once they are pasted into the map. However, connecting symbols don't scale - as you have already discovered.
    If you want to make the connecting cliff symbols bigger you have to draw the line of cliffs at the default scale, and then scale the whole thing up as one long snake of cliff symbols, which is easier to do if you group them first. That can still be tricky, though, because it requires that you can draw a miniature version of the cliff line by eye, perhaps to one side of the map.
    Alternative methods that you haven't already tried out are a bit more complicated. You could make your own relief shading sheet like this one I did for a city on a very steep island city, lit from the south east.
    But that requires that you have an eye to see where the shadow needs to be in the first place. All good if you do, but if you can't see it in your imagination first I don't recommend it.
    Another hand drawn method I've tried is explained in this blog article here: https://rpgmaps.profantasy.com/orde-on-the-rock-map-analysis/. It's a bit easier than Merelan City, but it will take a bit of time and care to set up. If I were trying to convert this map (image below) into a hollow mountain I would sink the entire city into a dungeon-style depression into the top of the plateau to give the illusion of a cave with the top of the mountain sliced off.
    The FCW file for this map is contained in that blog article if you want to use it as a base for your own map.
    These are not the only ways of generating the impression of height differences in a map. There are plenty more, like Shessar's tutorial here: https://forum.profantasy.com/discussion/9155/dd3-battlemap-tutorial-part-3-adding-contours
    Daniel Pereda De PabloJimPC.C. Charron
  • CA style development - "Darklands City" (issues for September and December 2021)
    Ok. We have all the animals I've got time to do this time around - cows, bulls, horses and sheep.
    With only a few days left before handover, I can do a couple more things now. I'm tempted to go for ruined versions of a keep, the bridge and maybe a tower if I can get it done.
    MonsenWeathermanSwedenTheschabiroflo1JulianDracosdragarhirDaltonSpence[Deleted User]RaikoDaniel Pereda De Pabloand 3 others.
    A ditch at city scale is relatively easy because you only need to worry about the general appearance of the thing rather than adding too much detail.
    Would something like this do?
    That's a fractal polygon of the darkest grass shade drawn on top of the field with those three effects employed to give the illusion that it is sunken into the field. That's a dark glow set to outer, a pale shadow of the same extent, and an edge fade inner that is twice the width of the other two. You could use the same effect in any city map. I will find a way to leave it in the example map for you.
    I've made it drain into the marsh and put mud in it instead of grass, so it makes sense in the map now
    roflo1dragarhirJimPGeorgeRaiko
    I'm already worried about my cows, Wyvern! LOL!
    I think I will try to straighten the neck of that one with the very long neck. They all look like their walking around in circles.
    Hens? They'd be the little red dots I added (not really - just teasing ;) )
    It was touch and go as to whether the larger animals were worth it at this scale. They really are completely tiny with not much in the way of detail.
    Wyverndragarhir
    Well, I did some more versatile ruins that don't have the dark blur around them, so that you can put them either flat on the ground or on a sheet with a shadow. After that there is a drawing tool to add a floor if desired, or you can fill in with debris.
    After a lot of messing around learning how to draw them, we now have horses and cows. Sheep and pigs to come (I hope). That should give everyone enough things to fill the land around their towns with now that there are 11 different kinds of field :)
    I have a feeling that the animals would have been more use in a dungeon scale setting, but they're there now.
    [Deleted User]roflo1WyverndragarhirJimPGeorgeRaikoGlitch
