- Loopysue
- 9,980
- Member, ProFantasy
- 9,863
- June 29, 1966
- Dorset, England, UK
- Real Name
- Sue Daniel (aka 'Mouse')
- 27
        The Creepy Crypt project
        Weird lines when I export my map (glowing effect?)Each of those bands is a pass made by the rendering engine. You can use wider passes by typing the command EXPORTSETMPPP and hitting return. The command line will tell you the current Maximum Pixels Per Pass, which at default setting is 4000000 (4 million without commas). Try typing 40000000 (40 million), hitting return, and trying your export again.
        Al Shammar - Cities of Schley fortified oasisWell, there are actually several ways of getting the shadows to behave themselves properly. That was only one idea, which may or may not work for you. The other way is to create a new sheet called something like CLIFF TOPPING and use it to draw a shadow-casting plateau that covers the entire area of the higher ground a bit like this. Here is the FCW for you so you can show and hide sheets and see what I did. It might be harder or easier to do it like this. I don't know. Only you can tell what issues might arise, as the creator of the map. And here is the alternative I described before. I haven't even tried to imitate those beautiful colours you created, but these are just 'how to' examples ;)
        Difficulty with choosing what terrain type to put where on my map (Overland Mike Schley style)You're welcome :) If its a plain, its a plain. Don't be afraid to map it as it is. There are plenty of symbol assets in this style to add points of interest across that vast plain. Spend some time looking through the symbols and picking out things you could add to a plain. Maybe paste them somewhere out of the way in the ocean or outside the map so you don't forget what they were or where they were. It's easy enough just to move them into position later, or to delete them if you change your mind. Have you downloaded and installed the free monthly content for Mike Schley overland? This style is still growing. If you haven't, you will find the single download file listed under CC3+ on your downloads tab when you log into your account.
        Difficulty with choosing what terrain type to put where on my map (Overland Mike Schley style)You're worldbuilding here, even if it isn't a whole world. That's a huge task if it's done properly, but most of us manage with a very basic understanding of how things work on a very general level. Manmade terrain, like farmland, will tend to be at the lower altitudes where there is fertile soil and water, so the river idea isn't as bad as you think. but perhaps it would be easier to place the farmland if you add the settlements and roads, since no one is going to farm a fertile valley that is hundreds of miles from the nearest large town, and which has no roads to transport the food to that town. Settlements themselves will tend to be on the coast where there is good fishing or good access to oceanic trading routes, preferably both. Or they will encroach inland up the larger rivers, particularly if there are resources to be had - like timber, mineral ores or just to farm the land to feed a growing city at the mouth of the river. They can also arise along major overland trade routes, particularly where these cross natural barriers like rivers or either side of a mountain pass. Wherever man isn't building cities or farming, the rest of the land will probably be far more dependent on climate and altitude. After all - why waste magic on land that is no use to man? Forests have tree lines that respect both altitude and latitude. Deserts, with a few really obvious exceptions, tend to appear at 30 degree latitudes on Earth because of the lack of rainfall where the Hadley Cell circulation causes descending air. https://en.wikipedia.org/wiki/Hadley_cell Deserts also appear in places like Chile over a much wider range of latitudes, where a cold sea current flows up the South American coast from Antarctica and fails to fill the air with moisture, causing little or no rain to fall on that side of the Andes. That's more than enough to be thinking about, so now on to the practicalities of making that swamp and marsh terrain work together. Both of those terrains are placed on the same sheet by their respective drawing tools, called LAND FEATURES. So where they overlap the Edge Fade, Inner doesn't fade the edge of the individual polygons, but only the outside edge of both the polygons taken as one mass The solution is to add a new sheet either just above or just below LAND FEATURES and call it something suitable, like LAND FEATURES 2, copy the sheet effects from LAND FEATURES to the new sheet, ok that and then move either the marsh or the swamp texture to the new sheet. Here I have moved the swamp fill to the new LAND FEATURES 2 sheet, which places it above the marsh and fades the edge. If I want them the other way around I might move LAND FEATURES 2 above LAND FEATURES in the sheet list, or move the polygons, each to the other sheet.
        ![[Deleted User]](https://secure.gravatar.com/avatar/c75d9a245b74d9c59be0999ea81ca541/?default=https%3A%2F%2Fvanillicon.com%2F92add7f8c954488718110edc4896ad39_200.png&rating=g&size=200)
