9,978
Member, ProFantasy
9,861
Birthday
June 29, 1966
Dorset, England, UK
Real Name
Sue Daniel (aka 'Mouse')
27
  • SS6 - Isometric Cities
    There is a live stream here if you want to see more of it than in an image.
    Here are also a couple of extracts from the extra example maps I made.
    You will find other examples of the style already present on the forum, and if you have your newsletter option ticked on your account page you should by now have received your early uptake offer voucher. If this didn't happen for you please contact Tech Support.
    [Deleted User]hsv216ScottAJimPRickopablo gonzalez
  • Winter Forest Trails
    It's already booked for March 2023, Jeff ;)
    Jeff BGlitcharsenico13JimP
  • Forest Trail project - part 1
    Ok, this is a benchmark image just to show I'm still working on part 2. My computer is giving me the blue screen of death on a regular basis and I will be reseating the RAM to try and cure it this evening. If I fail and it all goes wrong it will have to go for professional repair. And if that happens no work will be done for maybe a fortnight. I will also not be around on the forum in that same time.
    This is the ongoing work on the waterfalls - very obviously not yet finished. The first image shows them without a shadow on the face of the cliff, and the second one with.
    JimPMonsen[Deleted User]EukalyptusNowWyvernMythal82roflo1Calibre
  • help. struggling to readjust border/coastline size on continents.
    You're welcome :)
    johnsmith
    It sounds like you are using a style which has separate coastlines. Look at your sheets in the sheets and effects dialog. If you have a sheet called LAND and a sheet called COASTLINE then to adjust only the coastline thickness pick the COASTLINE sheet and hide all the others. Then you can pick the coastlines and adjust their width and reshow the rest of the sheets.
    A general note that might help in the future - if a polygon has any kind of line width greater than zero the fill will vanish and leave just the outline.
    johnsmithhsv216
