- Loopysue
- 9,972
- Member, ProFantasy
- 9,853
- June 29, 1966
- Dorset, England, UK
- Real Name
- Sue Daniel (aka 'Mouse')
- 27
Sinister Sewers - Style Development Thread (CA207)
Hi guys :)
I've been asked to do a 'small sewer style' for next year's Cartographer's Annual. I already have an image of pipes and grungy dirty fills that I can do. Have you got any favourite sewer maps you want to show me for inspiration? If the map isn't yours please provide a link to the original on the artists page rather than post a 'borrowed' copy here.
Thanks! :D
Misterious Land feature
You have Transparency Acne with the fills that are more or less identical to the Land texture bar some inking. That is where the render engine gets confused by pixels that are identical to the pixel on the underlying sheet and discounts it as being transparent. This creates a tiny 'hole' in the overlying polygon to which all the sheet effects are then applied the same way as they are to the outer edge. So from a percieved pinhole you get a very real edge-faded hole - acne.
There are a few different ways of dealing with it but the easiest one in this map is to use what I call a 'backing sheet', where you place a plain polygon underneath the top one by copying the problem polys and their sheet effects onto a new sheet between them both and changing the fill of the new polys to some solid colour that is sufficiently different to both textures that the render engine understands there are no holes in the topmost polygon.
I hope that makes sense.
I've created just such a backing sheet in this one for you:
Color key isn't working again
Battlemap collection for personal use
