- Loopysue
- 9,967
- Member, ProFantasy
- 9,852
- June 29, 1966
- Dorset, England, UK
- Real Name
- Sue Daniel (aka 'Mouse')
- 27
Almost all Entities have disappeared
Merry Christmas, Happy Solstice, and Happy New Year!
Live Mapping: Christmas Map
Hi everyone! :D
Tomorrow, Ralf will be going festive with a Live Mapping session using the Winter Village style to create a nice little map for the holidays.❄️☃️
Come join us live on Youtube and join in the fun here: https://www.youtube.com/watch?v=fud5YoQhXAs
Or watch it here on the forum later if you miss the show.
All are welcome :)
There are a few things that aren't on the right sheet, but I'm not sure which sheet these things should really be on.
For instance, you have what appears to be the landmass on the POLITICAL BORDERS FRONT sheet, which is on top of most of the other stuff - hence everything vanishing.
This is what's on the LAND sheet.
And this is what's on the POLITICAL BORDERS FRONT sheet
If I start moving stuff around between sheets for you that will leave you in an even bigger mess, so I have turned the background to the sea texture and left everything else as it was.
If you want to move things between sheets, like moving the land to the LAND sheet from the POLITICAL BORDERS FRONT sheet, first isolate the POLITICAL BORDERS FRONT sheet by hiding all the rest (that's what is shown in my second screen shot). Then right click the Change Properties button on the left and pick Move to sheet...
Select all the land polygons and hit D for do it, then pick the LAND sheet as the destination.
I've noticed that you appear to have the land polys and a set of identical black outlined polys on the same sheet and layer, so you may have to select by colour or fill to separate them. Select options can be accessed by right clicking when you are asked to make your selection.
a prototype under ground home for a dragon and some questions
Thanks Helen :)
This is just an analysis of what's there and what isn't on the WALLS sheet alone.
There are 3 entities on the walls sheet. One is a spiral staircase symbol, and the other 2 are lines drawn with one of the Bogie's Mapping Collection tarmac fills. I don't have the BMC installed, so these are all red X entities on my PC.
There is a Color Key on that sheet, but there are no pink polygons or lines, so nothing is being cut.
