9,970
Member, ProFantasy
9,853
Birthday
June 29, 1966
Dorset, England, UK
Real Name
Sue Daniel (aka 'Mouse')
27
  • ATLAS WIP: The Vale, Panaur
    Thank you! :)
    All the terrain colours are drawn on the same sheet and blurred into one another before they are blended to the parchment background. So the answer is kind of yes and no. Yes it matters if you suddenly cover all your mountain background with lots of green lowland grass colour, but no, because you can easily bring the mountain background polygons back to the front using the bring to front tool.
    Similarly, if you wanted to put a general greenish background behind what you have already done to cover all the white (not saying you should, but just as an example), you could draw that map-wide extent and then send it to the back of that sheet.
    jmabbott[Deleted User]Theschabi
  • Mouse Pointer Tooltips
    Hi James :)
    Go to Options in the Tools menu and check the little box called 'Display floating prompt'.
    DoubleDoubleNumberSixDaishoChikara
  • How To Save Image Without White Box Surrounding It
    Ok Joe. Thanks for the explanation.
    You could do the same thing in GIMP, using Select all, and then shrink the selection by 2 pixels and do a Crop to selection.
    DaishoChikara
    @jslayton - I think it should be possible to get this result with most maps where the MAP BORDER green rectangle coincides exactly with the background and if you hide the decorative frame (if there is one). I'm very convinced that it happens as a result of antialiasing the edge of the map, and because the usual drawing area and/or SCREEN is white.
    EDIT: yes - I can make the map I have open do it if I hide the frame I gave it and export a rectangular section. In this case the antialiasing (set to 66%) has mixed the line of pixels at the outermost edge with the white of the screen and turned them all noticeably paler. If the AA was lower it would be probably be even more noticeable.
    Here is the same thing again with only 20% AA
    I had to re-show the layer boundary in GIMP so you could see it against the pale background there.
    But maybe it's nothing to do with the AA (proving the first part of this comment is actually wrong). Here it is again without any AA
    I think this may be why most styles have at the very least a black outline rectangle as a visual frame.
    The other thing I've only just noticed after 5 years mapping with CC3 (I always usually have a decorative frame so don't ever see this normally) is that there are 2 pixels of white on the top and left hand sides, where there is only one pixel of white on the bottom and right hand sides.
    Another thing I've only just noticed is that despite there being no AA at all on this last image the white isn't pure. It contains tints of the colour from the map. Here (below) I have manipulated the Gamma to show these up clearly for what they are - apparently random colours.
    A further experiment proves it is the screen the render is capturing, even though the rectangle being picked is exactly the map extent. Here I have kept the same settings as before but turned the screen black.
    DaishoChikara
    When you Save as... click the Options button and check the Crop image to aspect ratio and Restrict image to map border boxes.
    That should crop out all the white stuff around the outside edges of your map.
    To hide the legend you will need to hide the sheets those parts are on before you export the map.
    DaishoChikara
