9,987
Member, ProFantasy
9,864
Birthday
June 29, 1966
Dorset, England, UK
Real Name
Sue Daniel (aka 'Mouse')
27
  • help. struggling to readjust border/coastline size on continents.
    It sounds like you are using a style which has separate coastlines. Look at your sheets in the sheets and effects dialog. If you have a sheet called LAND and a sheet called COASTLINE then to adjust only the coastline thickness pick the COASTLINE sheet and hide all the others. Then you can pick the coastlines and adjust their width and reshow the rest of the sheets.
    A general note that might help in the future - if a polygon has any kind of line width greater than zero the fill will vanish and leave just the outline.
    johnsmithhsv216
  • NW middle-earth redux
    That looks a lot better with the bevel on the land too. How about using an Edge Fade, Inner on that sea contour to blend the two ocean colours together just a little?
    JulianDracoswhit2468
    Looks pretty good already :)
    Have you considered making the textures larger? Sometimes the detail can be a bit too small to look like anything much. And don't forget that you can also use the same texture on different sheets with different colour altering sheet effects.
    whit2468
  • Which styles work best with each other as you scale down from world to regional?
    You could use a variety of styles that might reflect the culture of the map maker. These days most real world maps seem to look fairly similar, but that was not always the case.
    NZgunnerJimP
  • Map with x signs
    If that is where the FCW file started out, then you will be fine as long as you never move the map from your desktop. To use your symbols more freely and be able to move your maps around without worrying about red Xs you really need to store all your symbols in subfolders of the Symbols folder.
    These videos by Remy Monsen explain a lot of things about importing third party symbols if you are interested.
    https://www.youtube.com/playlist?list=PLulP-cGMLxw4qTpXfilRHgbDUg8WvrEX2
    If you need to upload an FCW again you can do that right here on the forum. Just click the attachment paperclip. Or you can do the same in a private message to one of us if you prefer.
    JimPScottA
