 - Loopysue
 - 9,987
 - Member, ProFantasy
 - 9,864
 - June 29, 1966
 - Dorset, England, UK
 - Real Name
 - Sue Daniel (aka 'Mouse')
 - 27
A Question about Political Borders
If you are using a drawing tool to draw the polygon it might be restricted to operate only within the map border. No need to redraw anything. Hide everything but the sheet the border is on and use the move node tool |CC2DYNEDIT| to pick and move the nodes beyond the map border sufficiently for the visible part not to show within the map.
The first move might be guesswork, but when you show everything again you can adjust the new positions of the nodes you have moved. You hide everything the first time you move them so you don't pick anything else that happens to be aligned with the map border.
Marine Dungeon 2
Julian is right about the 2 part annuals. It's not actually possible to do all the work in one issue due to the time limitation. Even though the style is done in two halves it doesn't make sense to generate 2 separate folder systems and two separate templates when its all the one style.
I don't recall the two parts of MD ever being sold separately. If an annual is done in 2 parts those two parts must be part of the same annual. It wouldn't be fair to expect someone to buy 2 annuals just because they happen to like that one style.
What Style for 1600-1700 West Indies Map
You can solve the white background by putting the symbols behind the parchment and using a Blend mode effect on the parchment set to Multiply and 100%. This is how the parchment version of SS6 was done.
The white parts of the symbols are to obscure the bits of other symbols that might appear through them.
These symbols all have white backgrounds, but the parchment is multiplied over the top of the entire map.
If you decide to use any of those sets mentioned by pvernon, there is a comprehensive section in the Tome of Ultimate Mapping covering how to create your own symbol catalogues, or if you prefer to watch there are a couple of videos created by Remy Monsen here:
https://www.youtube.com/playlist?list=PLulP-cGMLxw4qTpXfilRHgbDUg8WvrEX2
Does RGB Matrix Process work on Symbol Sheets?
It's mainly to do with the drawing order.
Symbols are by default drawn twice to ensure the semi-transparent pixels are not detrimentally affected by the sheet effects. However, the whole map effects are done last of all, and will affect the whole drawing, no matter how many times everything has been drawn up to that point.
You can disable the second drawing of the symbols using DELAYDRAWSYM, but this will damage semitransparent pixels in the symbols. You might not think there are a lot of semitransparent symbols but in truth the edge of nearly all symbols is antialiased, so there will always be a very thin fringe missing, and that may be enough to make the symbol look odd.
DELAYDRAWSYM automatically reverts to 1 next time you open CC3.
Having said all of that there are notable exceptions to the rule. Most house symbols will respond to colour modifying sheet effects because of the presence of map files, which control the shading of rooftops. City Cliff symbols also have map files, and will also respond to these effects.
