 - Loopysue
 - 9,987
 - Member, ProFantasy
 - 9,864
 - June 29, 1966
 - Dorset, England, UK
 - Real Name
 - Sue Daniel (aka 'Mouse')
 - 27
Top down symbols for overland maps.
The thing about top down mountains is that they are pretty inflexible as symbols. Hill shading means they can't be rotated or mirrored, and that means you need maybe a hundred symbols instead of just the usual 20 or so.
You might think that using a map file would be the solution, but at the current time if you have a faded edge all the way around a symbol as would be desirable for a top view mountain or hill to blend it into the background properly, the map file doesn't work properly. Faded edges upset them quite badly to the point where you end up with strange white strips of missing rows of pixels in the resulting symbol. I haven't worked out how to get around that problem myself, which is why I haven't yet done a top view overland style.
From Quillan to Montsegur
WIP Goldenlilly Dungeons
That grey overlay...
Have you considered using a nearly black one and adding a Blend mode set to Multipy and about 15-20% to that sheet?
The reason I say nearly black is because a true black one would probably interract unexpectedly with some of the dark glows. The darkest grey, or the darkest brown should be ok.
EDIT: You might also want to put a Blur on it after the Color Key and before the Blend Mode to take out any sharp edges.
WIP: The Battle of the Lines
