- Loopysue
- 9,987
- Member, ProFantasy
- 9,864
- June 29, 1966
- Dorset, England, UK
- Real Name
- Sue Daniel (aka 'Mouse')
- 27
Having trouble with settings
You have to click Apply to see the result.
And yes - most of the terrain sheets have the same issue.
The difference between those two settings is that the Percent of View Width is really huge at '10'. That's 10% of the width of your window. If you set 10 map units thats just 10 miles rather than possibly a few thousand miles.
Moving objects in front of or behind in same sheet.
Something I didn't know...
The way symbols with some transparency are drawn is different to the way symbols with no transparency are drawn. One of the smoke symbols (the one we both had trouble with) has some transparency and that's why we couldn't get it to come to the front.
The best solution is the new sheet option in this case. As was pointed out to me it's probably best that the smoke doesn't have the same sheet effects as the bushes anyway.
WIP - Tomb of Shadows
Post-processing Map to Age It
