- Loopysue
- 9,987
- Member, ProFantasy
- 9,864
- June 29, 1966
- Dorset, England, UK
- Real Name
- Sue Daniel (aka 'Mouse')
- 27
Do any styles have East European Symbols?
Any Feedback to my first CC3+ Map?
Color key isn't working again
A Color Key only works on the one sheet that it's on. If you want to cut things on other sheets you need to make a new Color Key on that other sheet and add new colour cut out polygons to that sheet above the polygons you are cutting.
I actually missed a point above. The cut out shape must be on top of all the other shapes on that one sheet.
The Colour key works as long as you have these three things set up correctly:
- The cut out shape is on the same sheet as the thing you want to cut.
- There is a Color key sheet effect on that sheet, and its set to the same colour as the cut out polygon
- The sheet effects are turned on.
If you want to cut the same hole in other sheets, for example you've cut a hole in your land that you want to cut in the terrain that lies on it, then you will have to set up the same thing for that sheet as well. It doesn't work for multiple sheets, but only the one its on.
March 2023 humble bundle
