- Loopysue
- 9,984
- Member, ProFantasy
- 9,863
- June 29, 1966
- Dorset, England, UK
- Real Name
- Sue Daniel (aka 'Mouse')
- 27
Arce Ursi
That old hatched stone fill seems to be stuck in the DD3 repertoire, but there are other alternatives around. If you are looking for something reddish you could use one of the Dirt fills instead, or maybe the "Stone Lava Cooled" and a sheet effect to change it's colour to something more reddish.
If you have other add ons there's no reason you can't use a fill from one of them if there's one you would prefer. How you do that is use Insert File in the Draw menu and pick a pre-prepared blank map of that style (or the actual template file .FSC) and press ESC just before clicking to place it in your map. That will import just the fills for that style which you can then use in your map.
Issue 199
Issue 199
Interesting. Mine shuts straight away, but I do have the same pdf opening issue as you, Wyvern.
I use Acrobat Reader, which at first sight appeared to fail to open. But when I tried to open Acrobat with an unrelated pdf it failed to open again. I checked the Task Manager and discovered the relevant number of Acrobat processes were actually running. There just weren't any Acrobat windows showing and no indication in the Start bar that it was open.
(to open Task Manager press CTRL+ALT+DEL and pick Task Manager from the list)
I ended the Acrobat tasks by right clicking each one and picking End Task, then Acrobat opened normally, though of course not from the installer since that had already closed at the end of it's process.
New world, first draft
Good effort so far :)
Symbol size is always a tricky one. If I was aiming for something about the size of A4 I would do larger symbols than if I was making a map I intended to print as a really huge A0 poster. The consideration I make boils down to "Is this going to be identifiable as a mountain/tree/settlement at the size I intend it to be viewed". Even distance plays a part. If I wanted an A0 poster, but one that was pleasing to look at from a sofa that is 15 feet away from the wall I might make the symbols a bit larger than for an A0 poster to go on the wall behind my desk at a viewing range of only about 2.5-3 feet away.
It's very much a personal choice as well, so there are no hard and fast rules except to pick a symbol scale and try to stick with that scale throughout - unless you are making more of a landscape image or want a gigantic world tree somewhere.
Creating Legend/Map Callout Guide/Key
Hi Nic Cho :)
I created that particular legend by hand - typing everything in a succession of text objects aligned on the snap grid. Then I added the fractal shape behind it on a new sheet with either a Transparency or Blend Mode sheet effect on it so the map could still be seen through it.
If you want to have a look at the FCW for this map it's linked to this blog article:
https://rpgmaps.profantasy.com/orde-on-the-rock-map-analysis/#more-5755
