- Loopysue
- 9,977
- Member, ProFantasy
- 9,858
- June 29, 1966
- Dorset, England, UK
- Real Name
- Sue Daniel (aka 'Mouse')
- 27
Community Atlas - Forlorn Archipelago - The Bleakness - Dungeon of the Dragon
Is there any way to adjust contrast?
Settings to export PNG for use as a Symbol
Depending on the type of map you are making...
Dungeon style symbols are usually imported at 100 px per map unit
City symbols are usually imported at 40 px per map unit
Overland symbols are usually imported at 20 px per map unit.
So it really depends on what type of map and how big you want your shield.
a personal wish-list
How to make the line of "default cave" darker and wider
Ok, thanks.
If you want to make the wall thicker, hide all the other sheets and use Change Properties on the wall alone, giving it a wider line width.
If you want to make the sheet effects more prominent (the glows and shadows), you can edit each effect singly to give them larger widths or blurs. To do that, open the Sheets and Effects dialoge and pick the sheet, then pick the effect you want to edit, and click the EDIT button on the right next to the effects panel.
