9,976
Member, ProFantasy
9,857
Birthday
June 29, 1966
Dorset, England, UK
Real Name
Sue Daniel (aka 'Mouse')
27
  • A2 Forest Trail - Ruin Tower Battlemap
    If you ever want to get rid of that part you could try adding more terrain fills on a sheet above the cliffs with a small edge fade.
    Ricko
  • Creating a Template to simulate the Khorvaire Map
    The best way to see how it works is to open a drawing and add a Color Key effect to a sheet that has a polygon you want to cut a hole in. Add a Color Key sheet effect to that sheet, noting the cutout colour (magenta or colour 6 by default). Then draw a magenta poly representing the hole you want to cut on the same sheet as the poly you want to cut the hole in (the one with the Color Key effect) and hit refresh. I didn't understand it to start with, but trying it out suddenly started a whole lot of little sparks in my mind as I saw what I could do with it.
    A Color Key will also cut holes in city symbols, though not in symbols in overland or dungeon maps. It works like an inverted mask.
    @db2000 - sorry for hijacking your thread just a bit there!
    HadrianVI
    You can if you want, Hadrian, but it's easier to put a whole rectangle of sea over the map and cut holes in it making use of the Color Key effect on the WATER sheet.
    It's not really an original idea. Most city map styles have the water over the land. It's just an adaptation of that for overland maps.
    JimPHadrianVI
    Then when you start adding the colour patches for the terrain you can draw them as far under the sea as you like and they will be masked by the water when you refresh the drawing.
    (this is the point at which you might want to make some new drawing tools to add more orangey colours for the desert than the pinkish ones I did)
    JimPHadrianVI
    The reversal of land and sea only happened because I wanted to be able to use very soft wide blends between colours on the land without having to obey the coastline.
    It's actually the way water is usually done in a city map, so think of it as being an extremly large planetary city map.
    EDIT: and if you get stuck at all just shout again. Things might not be as simple as I've described, or work the way I imagine they will, but we will get there in the end.
    db2000JimPHadrianVI
