9,972
Member, ProFantasy
9,853
Birthday
June 29, 1966
Dorset, England, UK
Real Name
Sue Daniel (aka 'Mouse')
27
  • Question about Layers with Sinister Sewers
    It might not work perfectly, since the BACKGROUND TEXTURE is below the floors, but if you don't need that sheet, or only use it to outline the deepest level of drain, then you won't get too many problems.
    Royal Scribe
    Sinister Sewers doesn't use the usual wall cutting tools, so I think you would be all right doing that - as long as you realise it would become quite difficult to separate entities by layer. You would have to separate them by sheet instead.
    However, to separate the levels you might wish to have separate sets of sheets instead of layers, so you can cast a shadow (for example) on the lower levels from the upper ones. Layers don't give you that power.
    Royal ScribeJimP
  • [WIP] Playing around with Sinister Sewers
    There's a very subtle difference. You can see the edge of the water a little more clearly.
    How about just a plain old black polygon with one EFI set up like this?
    Or even that plus the Glow Blur Radius doubled to 0.5?
    Alternatively, how about importing the water texture from another dungeon style?
    Royal ScribeJimP
  • Struggling with TRACED Command
    I'm not sure why TRACED didn't work for you in this particular instance, though I suspect that if it had worked it might have traced around each of the lines and not the whole shape.
    Providing there are still only those 4 lines there and nothing else, have you tried right clicking the Fractalize button and using Line To Path on all 4 lines at the same time?
  • Where are bitmaps 'CA51' please
    The location of any bitmap file is given in the Fill Style dialog box in the 'file' window.
    If you want to add them to another map it's probably easier to use Insert file in the Draw menu, and pick the old map you mentioned but press ESC just before you paste it. Doing it that way will also import the correct scale from that old map.
    JackTheMapperroflo1
