9,966
Member, ProFantasy
9,852
Birthday
June 29, 1966
Dorset, England, UK
Real Name
Sue Daniel (aka 'Mouse')
27
  • Grimdark Fantasy (renamed "Darklands") - development thread
    Ok!
    To make the paper really worth it, the texture had to be very large, so I compensated for the strain on the cache by doing away with all bar 4 of the original textures and making the terrain plain colour polys that are multiplied onto the paper background so they look like they have been painted onto it.
    I think I've got the colours fairly similar.
    DaltonSpenceTheschabijmabbottOverCriticalHitWill Mason
  • Help Converting Fractal Terrains 3 landmasses into CC3+landmasses
    Hi Koshachiy :)
    The way FT3 and CC3 interact can be a little perplexing at first. FT3 exports in a range of formats, as you have already seen, but none of these formats correspond with an actual mapping style.
    I don't know which style you want to do your CC3 map in, but lets assume you wanted to draw a Mike Schley overland map using your exported coastline. This is how you would do it
    1. Open your coastline export and then open a second instance of CC3 by right clicking the CC3 icon and picking CC3+, so you have two maps open at the same time in two CC3 windows.
    2. In the new instance create a new overland map in the Mike Schley style.
    3. Go back to the coastline map and use Copy from the Edit menu (or CTRL+C). Watch what the command line is doing. Pick the coastline and Do It. You will need to give the app a copy origin. For that you can either click where you like or type coordinates in on your keyboard.
    4. When the copy is done (the pink highlight vanishes) go to the window with your new Mike Schley map and use Edit-Paste (or CTRL+V). Then you will need to position the cursor so the coastline is in the right place. Holding down the CTRL key while you move your mouse will allow you to scale the copy before you paste it.
    5. Click once only to paste the map, and then hit ESC to get rid of it off your cursor, or you might end up pasting it several times over - each time you click.
    Then you will need to use the Change Properties button on the left toolbar to change the properties of the coastline to have a land fill and be on the correct sheet (if it is not already).
    I hope that helps :)
    EDIT: I should probably warn you that if you have exported the coastline at a very high resolution the paste operation may take a few minutes. CC3 will attempt to refresh the view every time you move the cursor, even if that is only a tiny fraction. Even when the cursor is motionless the outline will continue to refresh in a wave like pattern. Don't be concerned by this. It is perfectly normal and to be expected when there may be several tens of thousands of nodes in active memory on the end of your cursor. CC3 just keeps going, though, and will only freeze up or crash if you get seriously impatient with it.
    Koshachiy
  • The Cult of Life and Death - Simple Dungeon Map
    @Raiko Lovely map. Well done :)
    If I use lots of colour keys I sometimes put all the colour key pieces on a separate layer and lock the layer so they can't be selected by accident. I haven't done it with all the maps I've used colour keys in, but those that I have are much easier to edit. It also strikes me that hiding and showing different layers with different sets of colour keys on them could be an easy way of hiding and showing whole rooms or sections of the dungeon during play.
    pdjRaiko
    Well, even if I don't do it, an annual is always a good buy :)
    MonsenJimP
    At the time I wrote that last comment I was just trying to work out what it meant as a result of being asked to do a grimdark version of one of my city maps for another member of the team.
    Since then, however, I've started generating a few fills and talked a bit with Ralf about a Grimdark Fantasy overland style for next year's Cartographer's Annual. The basic colour scheme will probably be cream->dull green->dull purple with blue water and gold leaf border. Not sure about anything yet, though, so it might not be anything like that at all.
    WyvernRaikojmabbottLillhanskristof65efenordRicko
