![Avatar](https://forum.profantasy.com/uploads/userpics/706/p4NPJ0AID2TIV.png)
HelenAA
HelenAA
- HelenAA
- 986
- Member
- 393
- Surveyor
- 6
Reactions
Community Atlas 1000th map Competition - with Prizes [August/September]
WIP Ettinsmoor and northern Narnia
Here is the final map! Loads of things kept on vanishing just as I thought I'd done, mainly the Narnian rivers and the pine trees so the rivers became the part that I dreaded looking at, and yes I had saved them between sessions!
I chickened out of doing my 'cameo' idea as it proved to be way more trouble than it was worth. Besides which the original map title ended in taking at least double the space that the Baynes one had.
Here is the latest version for comment. I had to export the cameo as a .jpg and paste it onto the map's .jpg form. I just could not import/insert the cameo into the main map. I'm probably going to change the contents of the cameo though. is it too small though? The scene comes from the first chapter of the final book, "The Last Battle".
EDIT: Having looked properly at the map, I'm pretty sure the cameo is way too small.
Ah, I've not got that annual. Thanks though, @Royal Scribe .
