whit2468
whit2468
- whit2468
- 2,717
- Member
- 609
- Surveyor
- 6
Reactions
Numenor
Large Map of Arda
the NW files are defeating me at the moment. I can only produce a low res version. Any higher and cc3plus crashes.
So this is unfortunately the best quality i can do at the moment.
note that the the shape of the NW doesn't match, the original continent map. I've redrawn it, to match the shape shown on later b/w maps in ICE products.
seven kingdoms
Numenor
seven kingdoms
hi, everything is done in CC3plus to produce the finished map.
I dont use the Annual Fenlon style for these maps. I use my own version, which i started making before that was released. though i did borrow some elements, so they could be used with each other. like the background and colour palette. This is still being developed and tweaked with each new map i start.
You are getting red Xs because you are missing bitmaps from certain locations. ive coppied the necessary images into my gallery.
Copy PF_B_Mountain directly into the folder below.
"C:\ProgramData\Profantasy\CC3Plus\Filters\Images\PF_B_Mountain.jpg"
For the bitmaps you need to create a new directory in the location below called Pete Fenlon B. then copy all the bitmaps into this folder
"C:\ProgramData\Profantasy\CC3Plus\Bitmaps\Tiles\Overland\Pete Fenlon B"
Your red Xs should then disappear when you load the FCW file
