Jeff B
Jeff B
Jeff B
5,899
Member, Betatester
1,238
Fairbanks, Alaska
Website
https://www.akbattletech.us/endoria/
Surveyor
  • Print Issue
    Sue,
    The edge effect works fine if you change the setting to use map units instead of Percent of View width and move it below the glow effect. suspect the effect is grabbing the purple glow. As during some playing around I had the entire CC3+ display window purple with the effect on.
    PNW,
    You should be using the map units option for your effects it will give you less problems than Percent of view width.
    JimPPNW AnglerLoopysue
  • Print Issue
    If you post the .fcw we can look at it and see if we can find the issue for you.
    PNW Angler
  • Catalogue symbols are all red crosses
    Beware you may have other issues if you are using a remote (active backup) drive when using CC3+ the syncing can cause you additional issue with the program, because when your Google Drive sees a change it will sync the file. Recommend you pick up an external drive as they are pretty cheap these days.
    I have the data drive on my D: drive and have a folder for my active and archive files I'm working also on the D: drive.
  • Winter Trail Project
    My problem with the rocks is that the snow on the rock is too flat no texture, That would be fine if the ground cover was also completely covered in snow but that is not the case. There should be more texture in the snow on the rocks and the larger rocks need some of the rock showing through the snow more to match the other ground terrain objects.
    Looking forward to this set of symbols but in real life I'm soooo tired of SNOW!!
    JulianDracos
  • Could someone please convert some .FCW files for me?
    I’ll do it for you. Send me a message and we can work out the details of the file transfer
    David David KatzmanMonsenLoopysue
