Jeff B
Jeff B
- Jeff B
- 5,899
- Member, Betatester
- 1,238
- Fairbanks, Alaska
- Website
- https://www.akbattletech.us/endoria/
- Surveyor
- 9
Reactions
[WIP] Atlas Contest : Ingensteds Village, Seal Island, Alarius
Thank You
I'll work on the shadows but I should also darken the global sunlight as there would be little to none this time of year. Maybe I need some fires set out for lighting.
Based on where the island is and the location of the village I think it's above the tree line (too far North) so I was not going to add any trees or bushes.
I do live in an area that cold but far enough south to have trees.
Still a WIP. Need to add some more details and adjust the fonts but thought I would post to get some ideas of what may need to be changed / adjusted.
Ingensteds is a remote village on Seal island in Alarius. The area is covered in snow most of the year and the sea ice rarely recedes from the land. The people that live in the village like or even relish the isolation. The community works together to collect food and collect resources they need to survive.
Community Atlas 1000th map Competition - with Prizes [August/September]
Upside down text on a curve
What I have found in the past is that how the curve/line is drawn affects this. Ie right to left / left to right / top to bottom or bottom to top. It seems that the programs takes that information and then the click point of where you selected the curve/line along with the option you selected in the dialog to determine how to draw the text. I did sample tests and then made sure I also drew the line/curve using the correct starting point I needed to get the text ithe way I wanted it displayed
Print Issue
