Jeff B
Jeff B
Jeff B
5,899
Member, Betatester
1,238
Fairbanks, Alaska
Website
https://www.akbattletech.us/endoria/
Surveyor
  • Just a map
    I like the map but the fountain, well and water trough seem out of place for a tent encampment. Maybe if there were some ruins of an old building they would not seem so out of place.
    RobPappinJimP
  • Richardson Roadhouse
    @DaltonSpence
    I will work on adding cart tracks and more muddy areas.
    The original thought was that half of the outer building was to be a blacksmith area but at the time there were no good symbols for that. I decided that after the building additions were made and it was turned into a roadhouse that the old blacksmith area would become a storage area for the roadhouse.
    This is a map I have been working on for a while now and decided to post it. It is based on the building I work in. I have remodeled the interior layout from the actual building. The outer building represent actual buildings apart from the main one but the stable was moved to reduce the size of the map.
    As always comments and suggestions are welcome.
    Loopysueroflo1JimPGlitchEukalyptusNowDaltonSpenceRicko[Deleted User]ScottALoreleiand 4 others.
  • A Country Town
    Thanks Sue.
    I think I'll keep it the way it is. Now that I added the shadow effect to the temple which I forgot earlier and made it smaller I think the coloring works for what I'm looking for.
    The copy I posted in my gallery has an added wall and horses to the top center building to make it the stable for town visitors.
    JimPLoopysueEukalyptusNow
  • A Country Town
    @EukalyptusNow
    Ok I made the recommended changes and added a shadow effect to the hedges and rock walls. I also changed the temple colors and toned them down a little.
    @Loopysue
    I'm changing the temple colors with RGB martix effects and / or Hue and Saturation adjustments on a separate sheet, as I don't want to edit the images themselves. The one I can't get to change is the Keep 01 symbol. I have not found a way to dark this up without editing the image itself.
    FersusLoopysueEukalyptusNowRickoCalibre
