Jeff B
Jeff B
Jeff B
5,900
Member, Betatester
1,238
Fairbanks, Alaska
Website
https://www.akbattletech.us/endoria/
Surveyor
  • [WIP] August Mapping Competition -- Vertshusen Distillery
    @Sue
    I think I made the changes you asked for and I started working on the rest of the floor. Changed the coal chute to a trap door and added the platform between both building sections so there is access to the second story.
    Comments and suggestions are welcome.
    roflo1Loopysue
    Basement First attempt at lighting.
    JimPLoopysue
    @Sue
    I made the requested changes in the basement and added the cart tracks.
    JimPLoopysue
  • Richardson Roadhouse
    First Attempt at lighting the roadhouse.
    Comments welcome
    JimPLoopysueRickoCalibre
    Jenin River Whiskey
    First Floor: The kiln room is pretty good still needs something not sure what yet. The whiskey making area is about done maybe some resizing is needed but it has the fermenting vats, distilling vats and condensing towers. The other half of the larger building section is still a work in progress and not sure what I want to do with that section yet. I still have the outside area to work on once I finish the outside. Also need to fix the coal chute area I think I'll just put a trap door there for the coal. Still trying to figure out how to get to the second floor of each building section. Thinking of an outside access with a trap door and block and tackle to get stuff between the floors.
    For the atlas version
    I will also do the three outer building as I feel they are part of the Jenin River Whiskey Distillery but per the rules they will not be built out for the contest.
    roflo1LoopysueJimP
