Jeff B
Jeff B
- Jeff B
- 5,439
- Member, Betatester
- 1,115
- Fairbanks, Alaska
- Website
- https://www.akbattletech.us/endoria/
- Surveyor
- 8
Reactions
Catalogue symbols are all red crosses
Beware you may have other issues if you are using a remote (active backup) drive when using CC3+ the syncing can cause you additional issue with the program, because when your Google Drive sees a change it will sync the file. Recommend you pick up an external drive as they are pretty cheap these days.
I have the data drive on my D: drive and have a folder for my active and archive files I'm working also on the D: drive.
Winter Trail Project
My problem with the rocks is that the snow on the rock is too flat no texture, That would be fine if the ground cover was also completely covered in snow but that is not the case. There should be more texture in the snow on the rocks and the larger rocks need some of the rock showing through the snow more to match the other ground terrain objects.
Looking forward to this set of symbols but in real life I'm soooo tired of SNOW!!
Could someone please convert some .FCW files for me?
The Lands of the Witch Queen
Nice map but I do have a few comments. Your white text is below the red region lines and needs to be moved above the region lines. Some of the text is hard to read where the red region lines runs through the text. I'm not color blind but the red text is very hard to read on this map. I know it doesn't bother some people but for me it makes the text hard to read even at the larger size. The smaller white text is much easier on the eyes and easier to read than the red text.
Happy Holidays !!
