Jeff B
Jeff B
- Jeff B
- 5,900
- Member, Betatester
- 1,239
- Fairbanks, Alaska
- Website
- https://www.akbattletech.us/endoria/
- Surveyor
- 9
Reactions
Text inside a box
I think I know what the answer is going to be but I need to ask. I'm trying to put text inside a polygon on a map I'm doing just like Maidhc O Casain did in his Callum's Curiosity map for the contest. I've read through the tome but it really doesn't say much. I'm guessing that in multi line mode I just have to guess where to put the returns to start a new line to get the text inside the area I want the text to appear, like I did for my contest entry which was only a list and not a couple paragraphs of text.
Is there an easier way to do text?
Question - Darklands - Active Sheet Effects - Rivers Run Green
Endoria
Yes that is what I did but most of the areas are pretty blank with just some landmark stuff.
Well I knew this was going to happen I just ran into memory issues trying to export the jpeg. This is a huge map with lots of stuff so now I need to figure out how to either reduce the scale or start over which I really do not want to do.
Here is what I have now. lower resolution as I could not export any higher.
Endoria
I have been working to bring the World of Endoria to life in CC3. The person I'm doing this for has been running a DND game in Endoria for 20+ years now and I'm building the map from his collection of crude pencil drawing and filling in the rest of the world as I see fit. The world is huge and it is taking longer than expected but I'm making progress. Now that the August Contest entries are completed I have been able to work on the Monster Lands and surrounding area to produce a regional map ina jpeg image as I have not broken out the region into a separate map yet.
I decided to post what I have been working on to get some feedback into what I can do better and what I maybe missing. The style is Sue's Overland Spectrum with building from Darklands.
I may post the entire map later as it is currently rough and only has some areas fleshed out but not real happy with some of those areas. So here is what I'm currently working on.
[WIP] August Competition - The Southern Gatehouse
