Jeff B
Jeff B
Jeff B
5,901
Member, Betatester
1,241
Fairbanks, Alaska
Website
https://www.akbattletech.us/endoria/
Surveyor
  • Community Atlas Project - Download information - Contributions Welcome
    @Monsen
    Thank You if you want to hold off placing the city map until I get the regional one done that is fine with me. I'm doing the regional map in a style not used too much and have just started it. Still not sure if I'm going to keep the style or combine styles to make the map more interesting.
    Just to make sure I'm headed in the right direction I have posted what I have done so far.
    DaltonSpenceMonsenLoopysue[Deleted User]JimPWazzebuWyvernMedioEukalyptusNowRicko
  • New install
    Nope use the key you already have.
    JimPWazzebu
  • [WIP] City of Mar-Goth
    Here are the final versions of the project.
    [Deleted User]LoopysueDaltonSpenceLoreleijmabbottAleD
    I'm currently working on a new city and using a different style this time around. The city is based on information from the person I'm making the map for so I'm trying to get as many elements into the map as possible. I have posted 2 versions of the map one with out the key and one with the key. The key version needs the fonts tweaked but I'm looking to see if they way I want to do the text and key works for people if I get the font style and coloring the way I like it.
    Comments and suggestions are welcome as always.
    roflo1WazzebuLoopysue[Deleted User]EukalyptusNowCalibrejmabbott
  • Text inside a box
    Think I figured it out, put the text inside a text file and then have the map open the text file. Way easier to adjust the text to fit into the desired text area.
    LoopysueOctorilla
