Jeff B
Jeff B
Jeff B
5,901
Member, Betatester
1,241
Fairbanks, Alaska
Website
https://www.akbattletech.us/endoria/
Surveyor
  • Forest Trail project - part 1
    Yes I say keep both give people more options.
    EukalyptusNowroflo1
  • [WIP] Winter Village
    Updated daytime version. Still needs some additional work but think it is coming along. Should have the final daytime and updated night version tomorrow.
    RickoMonsenLoopysueLoreleiadelia hernandez[Deleted User]WeathermanSwedenpablo gonzalezEukalyptusNow
  • A small cave complex for a side quest
    Is one of the fills your using the semi transparent ones with holes between the colors ie dirt t color. If you are the acne can be from the setting your using in the effects. try turning the effects off for that sheet and see what happens. It does look like your using one of those fills as I have had a similar issue with those when using effects.
    Night Version
    roflo1[Deleted User]LoopysueMonsenWazzebuRickoEukalyptusNowadelia hernandez
    Decide to try out the Winter Village annual. I have posted a daylight and Night versions. I have just started the map and I'm still working on the direction that I want to go with this project.
    I think it needs the annual needs more accessory symbols as it seems kind of bare.
    Comments and suggestion always welcome.
    roflo1[Deleted User]LoopysueRalfMonsenWazzebuWyvernJimPEukalyptusNowpablo gonzalezand 5 others.
