Jeff B
Jeff B
- Jeff B
- 5,439
- Member, Betatester
- 1,115
- Fairbanks, Alaska
- Website
- https://www.akbattletech.us/endoria/
- Surveyor
- 8
Reactions
[WIP] Winter Village
Forest Trail project - part 1
A small cave complex for a side quest
Is one of the fills your using the semi transparent ones with holes between the colors ie dirt t color. If you are the acne can be from the setting your using in the effects. try turning the effects off for that sheet and see what happens. It does look like your using one of those fills as I have had a similar issue with those when using effects.
