Jeff B
Jeff B
- Jeff B
- 5,899
- Member, Betatester
- 1,238
- Fairbanks, Alaska
- Website
- https://www.akbattletech.us/endoria/
- Surveyor
- 9
Reactions
Endoria
Endoria
Export to different styles from FT3 to CC3+?
That would be great if you wrote up the steps for this process and post it. I want to add a few new templates to FT3+ to use different styles.
Endoria
Text goes behind symbols
Make sure your placing your text on the text sheet and that the text sheet is lower (towards bottom) in the sheets list than the symbols sheet. Also make sure you haven't placed the symbols on the text sheet somehow. Make sure the text sheet is selected (checkmark) and hide all the other sheets and this will show you what is on the text sheet. You can repeat for other sheets to verify what is on the sheet.
The sheets are drawn from the top of the list to the bottom of the list. So anything above the text sheet list is drawn first and will be below the text. Anything after the text sheet is drawn on top of the text sheet.
