3,240
Member
5,521
24
  • CC4?
    Yes, CC4 is a work in progress. As CC3+ users, we have no definite information beyond that, so far as I'm aware. It will doubtless all be revealed in due course!
    EukalyptusNowWarstaffevildmguyRyan Thomas
  • Wall Mural Symbol
    This blog posting by Remy Monsen might be worth reviewing, as it will allow you to create an image of whatever you wish that looks as if it's been cut into the surface involved.
    JulianDracosLoopysueJimP
  • Erasing Outlines?
    Ctrl + F should do it, I think. It's the same command as Tools -> Drawing Aids -> Toggle frames using the drop-down menus, because what you're doing is toggling the frame (thin white line) options to show where the nodes are on a line.
    LoopysueLastofthemanyJimProflo1
  • Live Mapping: New Isometric Cities
    Thinking about the late-stream discussion regarding using the "normal" Mike Schley city symbols to create a top-down map, and then the isometric ones to show a pictorial impression of the place on the same map, with Ralf's comment about using vignettes to highlight important individual places within the settlement similarly, brought to mind the Middle Earth poster map prepared by Pauline Baynes (Tolkien's only approved artist during his lifetime). Digging around online, I've come up with this reasonably high-res version of the original on the Museoteca website, which shows why it came to mind. I used to have a copy of the poster, sadly lost somewhere along the decades since, though it remains strong in my memory!
    LoopysueJimPQuentenroflo1
  • Community Atlas: Dendorlig Hall - A Sort-Of D23 Dungeon for Nibirum
    Day 200 of 2023 seemed an apt moment for a fresh update on this project, so here we are, whole map first:
    Further tweaking of labels and minor map features has proceeded apace since my late June update, and the type-up of my notes is in the early part of the University, area 259, currently, while the hand-scrawled preparatory notes are nearing the end of the Manufacturing District, area 293. Still a way from the area 360 end, but well up on the area 200 the day per area idea might have indicated otherwise 😁. (And yes, I STILL haven't got round to adding a symbol key or map title...)
    For today's closer look, following last month's minor temptational mention, we have the extracted PDF notes for the less-well-off living areas of the Hall in The Dell, areas 191-224:
    All being well, still more to follow!
    Meanwhile elsewhere, most folks I'm aware of who were trying the D23 project seem to have been struggling to continue it of late. Some recent discussions on one of my more active Discords, where D23 was A Thing earlier, have indicated no one there's still persisting unfortunately, although a couple of folks on a separate Discord server were still posting occasional updates into early July at least. Certainly, having the base map and ideas for every area randomly generated in advance, as I did, seems to have helped keep my attention focused at least, so that might be a way to go for anyone contemplating something similar later this year or next, or on a smaller scale, for instance.
    LoopysueMonsenJimProflo1EukalyptusNowLorelei
