3,240
Member
5,519
24
  • City of Nyxotos for the Community Atlas
    Sorry, Frosty, I don't.
    However, a quick check online shows there are at least two CC3+ maps of the Isle out there, both from 2022. One is by Jason Hibdon, on the Atlas of Mystara website, the other is on the Talaraska blog. In neither case is there an FCW file provided, but it couldn't hurt to contact the people involved and ask nicely!
    I'm not sure if either may be on this Forum, or perhaps the Cartographer's Guild, as well.
    Royal Scribe
  • Another little battle map
    Just a thought, but did you set up the trees so you can hide the canopies, yet still show where the trunks are for use in ground combat? Of course, that also means you can hide any GM-placed traps under the canopy cover as well ๐Ÿ˜‰!
    EdEJimP
  • Annual Issue 15 - Heraldry Symbols
    I don't find it takes quite that long on my PC, but certainly it isn't as quick as "normal" symbols.
    I suspect the only way you might speed things up would be to amend every one of the symbols using Symbol Manager in CC3+ so that all parts of the symbol go on one sheet, while it still looks the same. This would prevent adjusting the features of each symbol that are currently on separate sheets using sheet effects, although you could still adjust the appearance of the symbol as a whole using effects on whichever sheet the whole symbol is on.
    That would be a lot of work per symbol, and you would be best advised to store the amended versions in a separate, new, symbol catalogue, so as not to change the original symbols in case you might want to use those again, or in case something goes wrong with the changes you've been trying to make.
    On the whole, Shessar's excellent artwork options might be preferable all-round, however!
    Royal ScribeJimPnlp138
  • Live Mapping: Parchment City (CANCELLED)
    Beat you to it Sue ๐Ÿ˜Ž!
    LoopysueRoyal ScribeJimP
    Yes, the charges are vector symbols, with many nodes. There are also multiple entities in every symbol - lines and polygons - and the symbols are set up to go onto multiple sheets too. That does all make things run slower than normal, as the symbol is redrawn after every movement of the mouse. Irritating, but just how it is, unfortunately.
    Royal Scribe
