3,238
Member
5,515
24
  • Missing bitmap fills for Annual Vol 3
    Unfortunately, the fills aren't included with this Annual as far as I can tell. From the Mapping Guide with this issue:
    "If you do not own Dungeon Designer 3, you can still use the png and pdf versions of the maps, as well as the adventure description of the ship. To create your own ships you will need a copy of DD3 though."
    The missing fill is definitely a DD3 one, Water Blue 5 Bitmap (or if not that exactly, it's one from the same Bitmap group).
    DD3 is indeed a separate ProFantasy product.
  • Welcome to the Updated Forum
    Thanks Remy. That's a bit disappointing, but trade-offs like this have to happen, I suppose. I'm still just using the Rich editor (that was the default originally, as far as I recall). Don't have a lot of spare time/energy for further experimentation currently...
  • [WIP] Community Atlas - Topographical map of Nibirum with ocean currents
    @WeathermanSweden: I think Quenten's provided you with more real-world ideas than you can likely use right now for ocean current names, though of course the names have changed over time in places, and a lot have regional (local language) variants too. The latter might be interesting to explore for Nibirum, perhaps.
    I picked "Drift" names for the two main currents I showed, partly because the North Atlantic Drift, the northern part of the Gulf Stream, is relatively familiar from my own time studying geography from/in the UK, and partly because I was dealing with relatively near-coastal areas, where less-active oceanic water streams seemed appropriate. I have much interest in mapping the ocean floors in fantasy terms, and the civilisations based there, so adding some current activity was largely automatic.
    With aspects like the altitude colour-key, I tend to add them on a map only where they won't be hiding anything that should be better shown. [It irritates me when published real-world maps aren't given the same consideration!] Otherwise, I simply set them in a separate side-bar of their own alongside (or below) the map. That has the further advantage they can be expanded to be easier to read, and other features, such as a scale, or notes on the map, can be added there as well. So here, you might add a key for the current arrow colours (and possibly the prevailing wind arrows, if these will be added to the same map), for instance, and maybe quantify what the different line thicknesses refer to, if relevant.
    As Nibirum has more-or-less Earth-like seasons, is it worth considering a pair of maps for the alternate half-yearly views of the currents and weather systems? There are differences on Earth like this, though it does mean a lot more thinking-through of ideas than maybe is warranted for a fantasy world.
    WeathermanSweden
  • Cartographer's Annual - all the issues linked in one place
    This really is invaluable, Sue. As I've printed-off the PDF mapping guides for virtually all the Annuals, I tend to remember if I've seen a given style somewhere, but if someone then asks, I end up hunting through the PF website pages to find it, usually guessing which year it's in first, because I can't find it in the mass of printouts otherwise...
    I've not explored anything like enough of the issues in detail to have favourites, though my ongoing Community Atlas mapping has provided opportunities to experiment with quite a few.
    @jmabbott If you're subscribed to the PF Newsletters, you'll find there are sometimes money-off vouchers available for webstore purchases in those, and the company has in the past run generous Black Friday promotions, which might make the complete Annual collection a bit less fearsomely-priced. It's how I completed my set a few years back; after that, it's "just" a question of keeping-up with it year by year. That's not so bad either, as if you're a subscriber, you usually get a time-limited, money-off renewal purchase option around the end of the current year as well.
    LoopysuejmabbottJimP
    Great looking map so far.
    I'm not keen on the altitude scale being on the later version though, as it's hiding part of the ocean current flows there.
    Stating the scale of the map (1:XXXXX - whatever it is) might be more useful than a physical scale that's accurate only for the equator, but the latter could be helpful to give a rough idea of the planet size involved, as Monsen noted.
    I just gave simple "Drift" names to a couple of the main currents on my Errynor/NW Alarius map, based on Earthly examples, so inventing more names for the major currents elsewhere would seem very reasonable.
    Similarly, continent names for the larger landmasses would seem in-keeping with this pattern.
    I suspect most prior mappers, like myself, have tended to assume similar major prevailing wind patterns to Earth's. So, NW Alarius is essentially Europe, and Alarius overall would probably see weather patterns similar to Europe-Asia. Beyond that though, things become a bit trickier, as the parallels with Earth aren't so exact, particularly the smaller seas between most of the continents. Be interesting to see what you come up with, however!
    WeathermanSweden
